Joost - dead over plusnet.
Hi
I have installed just Joost on my laptop - I use it over wireless over dsl at work and it's fine. However at home it simply doesn't work (DSL + wireess too). I'm not sure about what ports/protocols are used but I suspect shaping to be the culprit here - does anyone else have a similar experience?
Plusnet Staff
Plusnet Staff
I've been meaning to set it up for a while and try it out but not had a chance, Bob has and I'm sure he said it worked fine on our network. By doesn't work what's the actual problem with it?
mitchell20
Joost works here without any problems. On PAYG here.
By not working I mean that it attempts to play the content, stutters and then dies - displaying 'sorry - we're not able to deliver this content right now' - or something to that effect. I'm assuming that this is due to BW troubles.
yeah. I know assumption etc ...but I have little else to go on here.
What speeds and noise margin is your router reporting for your ADSL line?
SW.
3Mb FTTC
Sorry - @ work right now.... no access - will post tonight.
Ianwild
This is something I'm interested in. We've seen a fairly big traffic spike since last Tuesday in Gold traffic generally, and I was thinking this might well be Joost related.
I would appreciate more feedback from People using Joost, and if you still need an invite to use it I'd be grateful if someone could send me one - iwild@plus.net (otherwise I will try it myself this evening).
Ian
mitchell20
Ian
YGM
Ianwild
Fanks!
Any more people out there been using (Or not able to use) Joost?
Ian
Absolutely useless on BB+ Stutters like crazy or wont play at all.
Having said that it's a load of old crap anyway, and apparently uses huge amounts of bandwidth, so i removed it.
Kakkoii
Works fine here on Premier 1 2MB. If the video stutters it's not necessarily your connection, it can be your computer too.
If anyone wants an invite then feel free to PM me, it's pretty nifty.
I'm on premier - not sure if it's opt1/2 though. As I said before it works fine @ work - @ home it plays fine for a bit then simply chokes and dies.
Fixes: 69
Works fine for me on Premier.
Ian, I'll send an invite to work and we'll try it on the test rig.
Rgds,
Plusnet Products Team
Tried it this morning around 8am and it was aok.
15:30 and it's gone to sh1t.
