Its good
penguinni
Its good
The new layout is excellent - well done to all those concerned.
Now, how do I get me one of those avatar things?Huh
Re: Its good
Post the picture you want to use up to your web space then call it up in the profile settings using your url.
Example http://www.penguinni.plus.com/samplepic.jpg
Do make sure though that your graphic is 80 x 80 pixels maximum which is the size limit according to the forum notes.
(However I have checked the one that support are using and its wider than the 80 pixels!! ) :x
Then whenever your post is viewed the avater will appear.
penguinni
Its good
Thanks John. One Penguin looks pretty much like another doesnt it :lol:
Nice
Nice Change I like it
Keep up the good work
Zak
Cool
