Is the Help and Support Contact Us Borked
Fixes: 57
Whenever I try to use the Contact Us from Help and Support I get this
Template Error: loadfile: While loading lights, /share/admin/portal/servicestatus/plusnet/servicestatus_lights.html does not exist or is empty.
Halted.
craigbrass
There is an issue currently causing alot of problems. It is being worked on now.
looks like its fixed but given the number of people having problems gettin access to websites should Internet Connectivity not be red?
craigbrass
The issue I mentioned is the issue that is causing a few portal problems, CSC problems, connectivity problems and a few other problems. No ETA has been provided for this being fixed but I hope it is soon as I cannot access any of my servers which basically means I can't get any work done!
