Is interleaving turned on?
Oxslow
How do I find out if interleaving is turned on? If it is how do i get it turned off?
Plusnet Staff
Plusnet Staff
Looking at the BT line report for your line it shows that interleaving is on. Some modems and routers will show whether the line is interleaved or using fast mode (non-interleaved).
To switch it off on some accounts there's an interleaving button under Connection settings on the left (it isn't there on all accounts so don't worry if you don't see it). If it's not there then if you raise ticket we can put an order in to do it.
Oxslow
Thank you for the quick reply. I know that in about fast mode and interleaving it is just netgear are stupid and dont give you that info in some modems.
I have just had a look in connection settings and it is not there I will raise a ticket now.
Plusnet Staff
Plusnet Staff
Don't know about all the routers but the DG834's it can been seen via the console:
http://forum.kitz.co.uk/index.php?topic=48.msg456
It's not unusual as I say for the icon not to be there, it's normally only there where our records are 100% certain of what BT's records say.
