Is It Really Slow Tonight Or......
Is it because its day 10 of getting Maxed? 402 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Have been pretty much stable at 5MB (Synced 7.6) (6000 Stable Rate)
But tonight is, as you can see, painfull.
Smiley
I've noticed a few evenings now that it all slows down to a crawl - well, hardly a crawl perhaps but much slower than at other times. I'm synching at 8128, max stable rate of 8000, regularly getting speed tests between 5,700 and 6,700, but tonight (and other evenings recently) it has dropped to about 2,000.
I guess that as our individual links get faster the contention issue kicks in...
Aid
Not this slow though for me at any time of the evening
mcsheepie
It's horribly slow tonight, i'm getting these speeds
15-05-2006 19:52:43 387.3 - after a reboot
15-05-2006 19:43:23 400
normally get about the 2mb mark (still stuck on 2000 stable rate, but thats another story)
Same here i log on at 8128
just done a speed test
http://www.speedtest.bbmax.co.uk/results.php?t=1147719272&v=39624
Its realy good tonight
im on day 13 since upgrade stable rate 6500
First hop pinging in excess of 200ms again.
Too many customers, not enough capacity.
Evil
Yes extremley slow 2nite... Between 400kbps and 800kbps for me.......AINT MAXDSL BRILLIANT.......Notttttttttttttttttttt. Pull your fingers out PN
Evil
Hence why none of us are getting anywhere near 8mb connection....Cost cutting to the extreme
Would PN like to commentHuh
If you can get on thn-ag1 that seems to be working better.
1st hop pings are only 10 - 20ms greater than normal. All other gateways are poor.
Perhaps the load balancer is goosed?
ceridwen
Interesting.
Was getting appalling speeds around 800Kbps.
Just disconnected to do a BT Speedtest and on reconnecting to PN I'm now getting 3500Kbps.
Overloaded gateway somewhere?
Matthew
passer
I'm on thn-ag1 and it's fairly reasonable for a Monday night (which in my experience is always slow). I'm getting 1.4 to 1.7.
It's usually the two pte gateways that go for a lie-down at the first hint of a capacity issue.
Fixes: 8
It's pants tonight.
Plusnet speed test: 2501.3
Disconnect - BT speed test 6335 kilo bits per second (Kbps)
Back to normal connection, Plusnet speed test 2273.5
I'm on ptn-ag2
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Adslguide test
Downstream 787.5 Kbps ( = 0.8 Mbps )
Upstream 373.1 Kbps ( = 0.4 Mbps )
Thats on a 8128 sync and stable rate of 8000kbps.
Come on this is crap.
C:\Documents and Settings\Steve>tracert www.google.co.uk
Tracing route to www.l.google.com [64.233.183.104]
over a maximum of 30 hops:
1 * * * Request timed out.
2 165 ms 165 ms 167 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 28 ms 29 ms 29 ms ge1-0-0-404.pte-gw1.plus.net [84.92.4.9]
4 29 ms 28 ms 29 ms 195.50.117.169
5 29 ms 28 ms 28 ms ae-0-52.gar2.London1.Level3.net [4.68.116.44]
6 37 ms 34 ms 35 ms so-2-0.metro2-londencyh00.London1.Level3.net [21
2.113.0.117]
7 91 ms 91 ms 91 ms 195.50.116.70
8 105 ms 102 ms 103 ms 72.14.238.240
9 103 ms 101 ms 101 ms 216.239.43.91
10 117 ms 115 ms 109 ms 72.14.232.141
11 111 ms 112 ms 113 ms 72.14.233.79
12 102 ms 110 ms 106 ms 216.239.43.30
13 101 ms 100 ms 101 ms 64.233.183.104
Trace complete.
Dead slow here as well Sad
