Internet disconections.. err???
ok,, so i have the 2meg ADSL line installed, and instead of using a solwise router, which i had HUUUUGE problems with i got my self a Cisco one UhhRaaar .. but now i get random disconections, like the internet times out and reconects. the best way i can discribe this is the fact that ICQ disconects even with a slight upset in trafic, and you get a window sayin "ICQ is disconected" then it recons instantly, same with IRC, MSN, any FTP up/ down load i have going etc etc
ping to www.google.com
Reply from 216.239.59.99: bytes=32 time=34ms TTL=50
Reply from 216.239.59.99: bytes=32 time=35ms TTL=50
Reply from 216.239.59.99: bytes=32 time=36ms TTL=50
Reply from 216.239.59.99: bytes=32 time=31ms TTL=50
Reply from 216.239.59.99: bytes=32 time=32ms TTL=50
Reply from 216.239.59.99: bytes=32 time=33ms TTL=50
Destination host unreachable. <----Disconects
Destination host unreachable. <----- Reconects
me = lost.. i have no idea why this is.. just wonderin if it is the cisco router or the line or somfin totaly different
Andy
I assume you have filters on everything plugged into the phone line?
The cisco should log everythign that is happening.
Can you check exactly what the connection is upto. Does it physicaly drop?
This is the same thing that was happening to me i would be online playing or browsing & my A220 PCI modem icon in the taskbar would beep & a little red x
would appear if i was on icq or msn it would disconnect me from them. then about 3 or 4 secs later the modem would reconnect itself. I got fed up with this so i bought a SpeedTouch PCI modem and now im getting disconnected completely & have to dial up again even tho the modem says im online. I'm also on the 2Bit homeworker package and does seem to happen a lot more frequently in the evenings than the day time
yea mine was doing it like every 10 mins (ish) from about 11pm to 4am.. maybe longer .. i went to bed
*shurg*
ah well if any one knows a solution i would be really greatfull
andy
Post..... The....... Logs........
Also, post your attentuation and line loss figures.
B.
that was the logs :p
Routers Connection Troubleshooting page :
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT)
ITU STD NUM: 0x01 0x01
Vendor ID: 'ALCB' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x00 0xB5
Capacity Used: 38% 38%
Noise Margin: 21.5 dB 25.0 dB
Output Power: 20.0 dBm 10.5 dBm
Attenuation: 46.5 dB 26.0 dB
Defect Status: None None
Last Fail Code: None
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 643 (1 spurious)
Activations: 1
Init FW: embedded
Operartion FW: embedded
SW Version: 3.9.220
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 0 2272 0 288
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 113 0 0
Header Errors: 0 64 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 2 2 2 4 5 6 6 6 5
10: 5 6 5 6 5 5 5 5 4 4 3 2 2 0 0 0
20: 0 0 0 0 0 0 0 0 0 2 2 2 2 3 4 4
30: 4 5 5 5 6 6 6 5 5 6 7 7 7 7 7 7
40: 0 7 7 7 7 2 7 7 7 7 7 7 7 7 7 7
50: 7 7 6 4 5 6 7 6 6 7 7 7 7 7 7 7
60: 6 6 7 7 7 6 6 6 6 6 6 6 6 6 6 3
70: 6 6 6 5 6 6 6 5 5 5 5 5 5 5 5 5
80: 5 4 4 5 5 5 5 5 4 4 4 0 4 4 4 4
90: 4 2 2 2 4 3 2 2 3 3 3 2 2 3 3 3
A0: 2 2 3 2 2 2 2 2 2 2 2 2 2 0 0 0
B0: 0 0 0 0 2 2 2 2 2 2 2 0 0 0 0 0
C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Training log buffer capability is not enabled yet.
AN SUMMARY
Interface Status : up
Interface IP Address : 10.10.10.1
Interface Subnet Mask : 255.255.255.0
DHCP Server Enabled : Yes
DHCP Network Address : 10.10.10.0
Default Router : 10.10.10.1
DHCP Lease : 2 Hour(s)
Primary DNS Server : 212.159.13.49
Secondary DNS Server : 212.159.13.50
WAN SUMMARY
WAN IP Address : 81.174.151.89
Line Protocol : up
VPI/VCI Number : 0/38
PPP User Name : buzzons@plusdsl.net
Automatic IP address : Yes
DSL UP Stream Speed : 288 kbps
DSL Down Stream Speed : 2272 kbps
VPN connection status : Down
im having this problem too....really annoying...and the disconnection time on my side is longer, sumthing like 15-30mins
if plus.net has got to do with it, hope they rectify it
Ianwild
HI Chaps,
This isn't normally caused by a problem at the ISP side, but it can be a hard one to diagnose. The tips about disconnections in the ADSL Troubleshooting guIde are worth reading, simply to ensure you are using the right terminology if nothing else.
Regards,
Ian
hi with the cisco router there is a way to monitor the connection, however you will have to monitor the connection in memory dont dump it all to screen more than likely the router will fall flat on its face, i forget the command to do this as im not at a route atm but you can use the ? to find thye command .
To keep the logging information in memory, you need to enter logging buffered from config mode.
To view the log use show log from the exec prompt.
I don't know if you have already done this, but the following config commands often prove very helpful when you come to figure out what is happening Smiley
service timestamps debug datetime msec
service timestamps log datetime msec
The only catch being, I don't know on top of my head how much information this will provide pertaining to the DSL. Normally it is just UPDOWN messages and the like. If this is not enough then you may need to apply some debugs for further information - any debug output will be included in the logging buffer if you don;t want to hold your exec session open.
Regards,
D'Essen
Simon_M
WAN SUMMARY
If this means what I think it does - that the router is getting it's IP address as a DHCP client, then I think it should be switched off for a UK BT ADSL connection.
While it is true that you don't enter your IP address manually & it gets dished out to you when you log on, it is not done by DHCP. Don't ask me to explain - I never did understand it, but I know I have to turn "Get by DHCP" off on the WAN side of my router.
1) I may have mis-understood your log, in which case I apologise for sticking my oar in.
2) Even if I am right, it may have nothing at all to do with your current problem.
The IP is assigned within the PPP initilisation packets.
well i think its fixed now, dunno how or why but it hasnt droped for over 5 hours Smiley
thanks to all
Andy
