Internet Explorer Help Please
Since Monday, when I click to open IE it takes about 2 mins for the page to fully open (and I'm so used to the 2 second Broadband !). I currently use the BBC homepage and have changed it to see if the problem is that - it isn't.
Outlook Express is fine - everything is fine - except IE.
Any ideas where to look for help ?.
Val
James
Hi Val,
I'd personally be inclined to try upating IE from the Microsoft website initially to see if this offers any improvement. Sometimes these little problems just happen sometimes and an uninstallation/reinstallation of the software is the best cure.
Thank you - I'll give it a go.
Also try clearing out your IE temp files via Tools/Internet Options.
D.
thejudge
Which version of IE are you using? (click on 'Help' and 'About Internet Explorer'), and what operating system?
XP - version 6.
I've remembered also that on Monday I did a Norton full system scan. I'm sure IE was ok before that.
I've tried the deleting temp files idea - no change.
Thanks all so far.
Fixes: 70
Strange this one as mine's stared being pretty slow on opening recently too. As I don't really use it though I've never been inclined to fix it!
Rgds,
Plusnet Products Team
