Internal ADSL cards
Internal ADSL cards
Hi support,
Ok im going to order the internal ADSL card Quick Link code 14XKWS from DABS.co.uk.
I just wanna know if this is going be ok for when i switch over to the home ADSL self install.
I have also found this card http://www.solwise.co.uk/adsl-pci.htm.
Im just double checking that im going to get the right thing.
Please advise
Many Thanks
Gary
RE: Internal ADSL cards
> Hi support,
Hi Gary,
This equipment should be ok. I do not have any information specific to each router and modem, but most ADSL equipment should work without problems.
Please let me know if I can help you any further
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Senior Technical Consultant...........for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
taeppa
> Hi support,
Gary,
I'd very much appreciate your feedback on this card when it's up and running. It looks like a good low-cost option. I'm currently torn between this and spalshing out on the much more expensive ADSL router - the pci card would be the simplest to set up and use.
Regards
Ken
