Intermittent Connection, Help!
Don't know if its just affecting me, but my connection keeps failing intermittently!
Its been like this since last Friday evening!
Connects OK for about 20-60 mins and then gives up. After a variation of restarting the router and PC, unplugging the ADSL connection, phone line, etc it will sometimes connect again, usually after about 30-60 mins of messing around. Then it'll connect again for 20-60 mins and the whole thing starts again.
I don't know if this is to do with the BT line or the problems with the Manchester region, I'm in Derbyshire so don't know if I'd be affected by that?
I've had a similar thing happen ages ago, but it cleared up after a day.
Any advice or info would be greatly appreciated.
Cheers
Nige
