Interleaving
Interleaving
Wonder if someone could advise me on whether I should have interleaving turned off or not.
During the day my line syncs at around 4.6Mbps and at night (10pm till early hours) drops to 4.2 ish. Not a problem.
My Local SNR doesn't fluxuate much from 12-14 and as such wonder if with interleaving off I wouldnt have any problems with line speed.
I ask because I would love to see my old pings of 20 or so in the UK where as at the moment I'm seeing 40+.
Hope you can help!!
James
Interleaving
If you're not seeing much fluctuation in your noise margin then we can try to remove interleaving for you. However, I would be a little aprehensive of doing so as your noise margin is already quite high.
Essentially it's your call.
Interleaving
Thanks James. Just a quick update on my line stats. Currently sync'd at 4.6, attenuation is 39 (normal) and SNR is 15.
Based on the readings I've given do you still think I'd be better staying interleaved?
James
Interleaving
I would have thought so yes. Trial and error could be rather painful Wink
