Interleaved
Interleaved
hi all
how do i go about having interleaved turned off
Interleaved
Raise a ticket requesting it to be done..
Usually applied to stabilise your line. So connection stability may be decreased by removing it, if you do a lot of online gaming then removing it will help your ping speed.
Interleaved
Where can I find out If I have interleaving turned on or off ?
I have never asked for it on but notice that this can be set to on by default for some customers.
I have noticed over the past 2 -3 weeks that My connection have constantly been dropping 2 -3 times a day..
So wanted to check if it was on or off.
Interleaved
eastcoastpc:
Have you been moved to Tiscali-LLU? If so there is a known problem with frequent disconnects. If so see the ADSL Dial Service Status and this thread:-
http://portal.plus.net/central/forums/viewtopic.php?t=47278
Interleaved
Hi.
Not on LLU here but am on BB Max & have been for the past 2 - 3 months..
Just curious to see if turning on interleaving (or off its already on) will make a dif to my constant disconnections.
But wondered where I can see if its on or off before I raise a ticket.
