Impossible download 6/8 7-9pm
Major problems tonight-Managed to get connected after a few attempts but web sites almost impossible to download. Signed on again at 9.20pm and everything OK- Why was this? This has happened before.
Did you see the Service Status posts? They might explain it.
No Im not an 0845 user I am on Connect Lite?
To my knowledge, you will have been affected by the problem as well.
jberry
The problems earlier did not affect Connect customers at all. If you were having problems accessing certain sites then you would need to provide traceroutes when the problem is occuring so we can diagnose the problem. Without something to start from investigating problems like this is virtually impossible.
Regards,
It affected ALL sites including initial Plus Net Home page download-I have not got a clue what you are talking about re trace routesHuh as an addition on Connect Lite unable to connect again this morning between approx 7.10am & 7.30am-Connected straight away at 7.50am-Service at present is unreliable.
Simon_M
Tracert is a program that traces the route of the signal from you to the site you are trying to reach.
Go to a Dos prompt/Command prompt - how depends on your operating system & how it is set up - and then type tracert followed by the name of the site. See example below:-
C:\>tracert portal.plus.net
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms IX-66 [192.168.xx.xx]
2 27 ms 27 ms 26 ms pth-ag2.plus.net [195.166.128.6]
3 27 ms 27 ms 26 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 27 ms 27 ms 27 ms gi5-0.pth-gw1.telehouse.core.plus.net [195.166.129.21]
5 32 ms 33 ms 32 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 32 ms 34 ms 34 ms vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 33 ms 34 ms 35 ms portal.plus.net [212.159.8.137]
Trace complete.
C:\>
Use copy & paste (again the method is slightly dependent on which operating system you are on) to get this into a Contact Us ticket.
