Idle timouts, but connection not terminating...try this!!
In relation to the problems we're experiencing on this thread
http://portal.plus.net/central/forums/viewtopic.php?t=36270
i've just had the most obvious idea...not sure if it works with a router, but if using a modem, go to Properties > Options > Redialing Options > Idle Time Before Hanging Up...change it to 1 minute...i'm figuring this should solve the problems for the time being in regards to reconnects if anyone leaves downloads on the go while they're out like I do!
