Idle timeouts Opt out
ChrisR
I've forgotten, does "Activate" mean Activate Idle Timeouts?
___oDiN__
yes
deactivate turns them off
if u see activate it means they are off already
I wish PN would change the wording on that page as it is confusing so many people (even me initially).
If you see If you still want to opt out, click the button below. above the button, then idle timeouts will happen on your line. You click the deactivate button to stop the idle timeouts from happening.
If the button says deactivate, clicking it causes the idle timeouts not to occur
If the button says active, clicking it causes idle timeouts to occur.
If that makes any sense.
