Idle disconnections - new?
bartstope
it's recently started happening to me, i don't access the web for a few minutes (maybe half an hour) and it has disconnected.
is it just me?
and can i turn this stupid thing off?
Mand
You don't have an idle timeout active from our side of things, this does not apply to your account type.
Is it a router setting? Or does your router log show any drops in connection?
What ADSL equipment are you using? Most routers have an idle disconnect option which is enabled by default which you need to turn off if you don't want it to happen.
bartstope
i've turned off idle disconnect, the strange thing is, in the logs it just says 'asdl link down' and wont reconnect again until a restart.
my router is a belkin F5D9630
That sounds like a problem with the router.
