Idle Disconnect
Idle Disconnect
It's incredibly annoying. Please stop it. It's my choice when I choose to connect or disconnect not yours.
I used to recommened Plusnet unreservedly to others as a great ISP who puts the customer first. I no longer do so.
LiamM
Idle Disconnect
If you look under Connection Settings down the left hand side there is an option to switch off idle timeouts if they affect you.
Idle Disconnect
Rgr - thanks.
LiamM
Idle Disconnect
No problem at all...
