[Idea 3391] Clarity in Billing
Itemisation of what is being billed monthly is unclear.
My Bill states £22.99. Everybody else seems to be paying for a £21.99 package, and that is what the latest emails indicate.
I have discovered that the extra £1 is owing to my .co.uk domain name.
:idea: It would be good if Plus Net could make sure that this and other extras are clearly indicated alongside the Billed amount to avoid confusion. :?
Reference thread: http://portal.plus.net/central/forums/viewtopic.php?t=28144
Thanks!
Anyone from PlusNet going to think about this one?? Sad
Account Details > Account Summary gives a break down of your account and what you pay for. I dont know if the domain is included in the details since I dont have an included domain.
Account Details -> Account Summary only tells me that I am on a £21.99 a month "ADSL Home-Self Install"
  • package.
    Under Account Details -> View Transactions -> invoice xxxxxxx I see the single figure £22.99.
    The extra £1 is the domain part for my .co.uk. My query in the original thread was I didn't know where this was coming from - and I still can't see where in my account details.
    I believe that PN should have an indications somewhere within my details of exactly what services I am subscribed to, plus the ability to cancel that part if required.
    We await for the PN comments Sad
  • OT - is it me that needs to do an upgrade to be on a premier package, or am I ok leaving "as is"?
  • csogilvie
    You should be fine as is... If you click "Domain Names" on the left hand side, it should tell you whether you are paying an extra £1 a month or not.
    No it doesn't It only indicates that a domain is registered and hosted.
    The original suggestion is that the invoice mentioned by Chris only gives you the total payable less any amount for referals.
    If you go in the supermarket and buy several items you get a list of what you have paid for.
    It's surely not a massive problem to do the same with the invoice for your ISP service. :?
    csogilvie
    It does, if you look down the bottom, or at least, it used to... it currently says "Opt In" - if you are paying it, it says "Opt Out" from memory, although it has been 2 years since I realised I was paying £1 more than I should be.
    LiamM
    But that really isn't obvious to Joe Bloggs.
    Like John said, you can go to Tesco, do your shopping and they give you an itemised list of what you're paying for. They don't expect you to hunt around the shop to break it all down yourself.
    A little more information on the confusion....
    www.grhodes.plus.com/public/AccountSummary.png
    Shows my account - Bill = £21.99 Monthly
    www.grhodes.plus.com/public/ViewTransaction.png
    Shows me with a history of paying £22.99 Monthly
    www.grhodes.plus.com/public/AccountDetails.png
    Shows my last monthly transaction, with me paying £22.74 because of a referral - so that means the previous page is actually incorrect.... it all shows that things are itemised on the bill, but NOT the domain name thing.
    This is the monthly amount that comes out of my Bank Account.
    www.grhodes.plus.com/public/DomainNames.png
    Shows there is no place to opt in/out
    So - PN - Why is there no consistency between the 3?
    csogilvie
    http://www.csogilvie.plus.com/images/optin.png shows the "Opt In" and when I had the £1 option, before I turned it off, it used to show "Opt Out". I wonder if you make use of the opportunity to Opt Out goes away...
    Interesting.... thanks for that
    I have had my .co.uk domain since I was a dial-up customer, and I didn't have to pay the extra then. I do not recall being given the opt in/out option.
    The other thing that adds to my confusion is that there is no apparent distinction between my .co.uk domain on the £1, and my .org.uk domain which is fully paid and hosted.
    csogilvie
    You could probably get the registration cheaper elesewhere anyway and not pay the £1 extra and still host the domains on your account as I do anyway - there should be no difference in them other than the £52.88 charge, verses the extra £1 a monht.
    Mine doesnt show that at all Colin. It only shows that I have a domain hosted.
    It did used to give me an option of paying or not in the past but its no longer there now.
    It would be nice if somebody in PN could comment on this..
    BTW - It was good to see all the moderator's comments - thanks guys.
    Oh....
