ISP Regulator
ISP Regulator
Is there an independant regulator for ISP's that I can talk to re my issues with PN & BTHuh
Cheers
ISP Regulator
Have you looked at the Ofcom website ?
http://www.ofcom.org.uk/
Smiley
carrot63
ISP Regulator
It's probably worth also taking a look at the Internet service providers Association code of practice at http://www.ispa.org.uk/about_us/page_16.html . As a member, Plusnet are supposed to be bound by its terms.
Ofcom will log your complaint and offer suggestions, but cant/wont offer any actual help in resolving specific issues in individual cases. If a provider gets enough complaints against them on a given issue, Ofcom might do something, although as they believe in "light touch" (inadequate might be another word) regulation, its more likely to be a gentle tap on the knuckles than a public dressing down.
