IP address
wickedray
IP address
Having connected, how does one discover what the IP address is that has been asigned to your computer.
Cheers, Ray.
RE: IP address
In Windows 95/98/ME goto Start > Run > type the following -
winipcfg
press enter. Ensure you choose PPP adaptor.
Chris
| Chris Rugen ................................ Unmetered & ADSL solutions
| Customer Support................................... for Home & Business
| PlusNet Technologies Ltd ........................... http://www.plus.net
+ ---------- My Referrals - It pays to recommend PlusNet ---------------
RE: IP address
> Hi,
> winipcfg
For win2k/XP open a Dos window and type
IPCONFIG
Note it has too be from a Dos window, not from Startbar|Run or the info won't stay
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
@ in #utgames #utchat #uthelp
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
wickedray
RE: IP address
Thanks for that. I am using W2K but it does not recognise IPCONFIG also I cannot find IPCONFIG.EXE
I wonder if it is an installation option?
Thanks for your attention anyway.
Cheers, Ray.
> > Hi,
> > winipcfg
> IPCONFIG
> IRC.UTCHAT.COM
wickedray
RE: IP address
Oooops! found it!
Thanks Gus
Cheers, Ray
> Cheers, Ray.
> > > Hi,
> > > winipcfg
> > IPCONFIG
> > IRC.UTCHAT.COM
RE: IP address
> Oooops! found it!
> Thanks Gus
> Cheers, Ray
Hi Ray,
Glad you found it, let us know if we can help with anything else.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
