IE7 and F9
Frogger
IE7 and F9
Today Installed IE7 Beta2, I was generally pleased with the beta, no problems found except on Force9 Member Centre. All the links under My Account; such as Connection settings, load without the main content which shows as blank.
Anybody else tried IE 7, had this problem or know of a fix ?
Colin
Frogger
IE7 and F9
To save you all the trouble,... I've just found this article
http://portal.f9.net.uk/central/forums/viewtopic.php?t=7129&highlight=ie7
IE7 update
Hi
I have been experiencing the same problem with IE7 and Force9's website. I have today (31st May) downloaded an updated version of IE7 (build 7.0.5346.5) and Force9's site works fine.
Hope this helps.
David
David_W
IE7 and F9
I'm using the exact same version number, new site design, same problem in that it doesnt work with IE7.
Frogger
IE7 and F9
I think that was the version I noted the issue with, but I downloaded it and still have the issue, for example the 'connection settings' still shows a blank frame.
Colin
IE7 and F9
yep I agree its still not fixed - having to use firefox to actually view the f9 portal
its even the same for their new status pages
JonathanW
IE7 and F9
We're still in the process of revamping the site, and we are looking to ensure that it is compatible with the newer version of IE. Though this is going to take a while longer than simply changing the headers of the page to make things more streamlined.
David_W
IE7 and F9
Quick update. IE7 on Windows Vista renders the site correctly, so its possibly a problem with IE7 on XP, either that or IE7 on Vista has an hidden option.
JonathanW
IE7 and F9
Cheers for that, I've passed the comments through internally.
I think this might be a case of MS playing silly buggers when it comes to their software. MAking IE7 not work fully on XP and have a few bits of code in Vista that make everything render properly. That might just be me being cynical though.
IE7 and F9
the version of windows vista is actually different
it is 7.0.5384.4
and I can confirm this version works as i'm currently using windows vista
regards
mike
David_W
IE7 and F9
IE7 Beta 3 currently renders the site correctly.
Frogger
IE7 and F9
Thank You
Fine now
Colin
