I've been maxed hurrah!
darkgen
However, what should my router settings be? I have a vigor 2600g and I'm looking at whether I should be using a certain type of encapsulation, Protocol or Modulation?
Currently they are set to :-
LLC/SNAP
PPPoA
G.DMT respectively.
I'm guessing the VPI/VCI are still correct at 0,38
Cheers, Paul
Craigiusmaximus
Glad to hear you have been maxed mate Cool
darkgen
Yeah, No complaints or anything as yet, if nothing else, my connection remains unchanged Smiley
Just wondering if I should change any of my router settings.
Snapshot of adsl status :-
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 2272000 bps US Actual Rate : 288000 bps
DS maximum Rate : 11200000 bps US maximum Rate : 896000 bps
DS Path Mode : Fast US Path Mode : Fast
NE Current Attenuation : 27.5 dB Cur SNR Margin : 30.5 dB
DS actual PSDM(C) : 00000007 US actual PSDM(R) : 00003e77
ADSL Firmware Version : 41e2be2c
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 20.0 dB Far SNR Margin : 21.0 dB
CO ITU Version[0] : 000f414c CO ITU Version[1] : 43420000
DSLAM CHIPSET VENDOR : < Alcatel >
INTL, DSTREAM bytes/depth= 1, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 1, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 72.
DSTREAM intl parity bytes= 0, intl codeword= 0.
CODE, USTREAM fast parity bytes= 0, fast codeword= 10.
USTREAM intl parity bytes= 0, intl codeword= 0.
As I say, the figures are unchanged. (specifically the DS and US max rates)
Cheers, Paul.
Craigiusmaximus
Im not too sure to be honest but im sure there will be someone on here to answer it i didnt think you had to change anything in the router just leave your line to sort itself out Cheesy
I thought G.DMT was for ADSL1? See if you can change it to ADSL2 or ADSL2+, which should give you better speeds.
Uhm.. 2272/288 looks like a fixed 2meg service to me.
if you was maxed I'd expect a more random sync speed.
(Ps you should be running in VC mode not LLC).
darkgen
Hmmm, yeah I would tend to agree, I'm merely supposing it was upgraded since the Plus.net Stable Rate page (as found here -> https://portal.plus.net/my.html?action=stable_rate) now shows me on "Hi-Speed broadband service" where as it used to be "IPStream 2000" or some such.
Maybe I have not been "MAX'ed" yet?!
But "VC Mux" should be my enscap mode?
Regarding modulation, since this is not a ADSL2+ compatible Modem, I only have the choice between T1.413 / G.Lite / Multimode and G.DMT.
Time will tell Smiley
Cheers, Paul
shellsong
If you were on MaxDSL you would definitely be synching higher upstream at least-- you're still on bog standard ADSL I'm afraid! Wink
Craigiusmaximus
gutted for him
darkgen
Yeah I've come to that conclusion and slipped the horses back in the stables.
*feebly blames plusnet for it's rate status page*
*ahem*, Smiley
Paul.
shellsong
With his SNR figures he shouldn't experience any real problems with MaxDSL-- only with PlusNet packet management and contention! Tongue
Question for Dargen- what and how to get to this stable rate page. The link doesnt show it up
Cheers
Keith
darkgen
Ahh I see the issue, that link has an erroneous ")" at the end, remove it.
As in :-
Paul.
Thanks Paul, got to that page and it says I can expect 8000kbps as the line should support this speed.Funny that PN tells me I can only get upto 2mb on it because of distance,line attenuation etc,etc.Feel like bursting into the Shall we dance song from King & I- but I wont.
Upto 2mb- that would be ever so much better than the 148 speed Im stuggling to get. Good old PN
Keith
darkgen
Apparently the information generated on that page needs to be taken with a pinch of salt, i.e. like the VMBU Wink
