I have a DNS problem, I think. HELP???
Hi.
I am not 100% sure but I think I have a DNS fault. On my browser I get long periods of "Looking Up", "Finding Site" or "Connecting To" in the status bar before the page comes up, and I sometimes get timed out. It's really annoying.
I currently have my router set to automatically obtain DNS IP from ISP, should I change that to a manually set PlusNet DNS IP, such as 212.149.13.59.
Ideas?
1 REPLY
Have you tried using the 2 alternatives?
212.159.6.9
212.159.6.10
I have the same issue at times hence I always use a multitude of DNS servers.
Regards,
