I don't understand my connection sometimes
ste
My connection can be ok for a while; i'm surfing along, minding my own business.. then all of a sudden, it just seems to run out of juice.... Like now, it's after midnight, and I lost about 0.7meg of speed somewhere... I just did a reboot of my router, and it's all fine again.
What causes that to happen?
The_10th
Where do you get the figure of 0.7GB from and have you performed speed tests?
ste
I usually get about 1.8mb, and it went down to 1.1mb--and it would have gone down more if I hadn't of rebooted, cause that's what it does. It just seems to run out of juice. I run the bbmax speedtest and watch the needle get lower and lower, and wonder what the hell is happening. No sooner had I posted and rebooted my router last night, my connection went off completely by itself. I couldn't get back on again at all. :? Always seems to do it either just before or after midnight.
Could it be everyone is trying to take advantage of the free usage all at once, d'ya think?
Fixes: 57
Can you check the errors reported by your router when your speed drops - a lot of errors could cause that effect and rebooting could switch to the less problematic tones.
ste
Hmm, I would if I knew where to look, my friend.... it's a Speedtouch 510v4 router. :? Any ideas?
ste
Sorry, but the manual that came with it is about as much use as glass hammer.
I've taken a look at all the stats, but I just can't find any error reports anywhere.:?
Fixes: 57
Just downloaded the manual for the 510v4 and it doesn't give that information.
ste
Nope, the link didn't work.. and sounds like your whole setup is different to mine. There isn't any - Broadband Connection / DSL Connection - details to get where you can get to... but thanks for trying to help anyway.
Fixes: 57
see my edit above - you are right about the manual
ste
Rubbish in it? I could write a better manual myself.
ste
Um, have you deleted a post? cause it's gone.
Fixes: 57
I edited it after checking the correct manual - sorry Shockedops:
ste
No worries.
