I can't believe it
mickm
I can't believe it
How's this for a solution?
I'm on FRIACO with ISDN. In common with many other people the service has been totally unusable this weekend, but don't worry - Plusnet have a solution.
They have removed the CLIs for my ISDN number and analogue line 2 so now I have a very expensive single analogue line with the computer blocking incoming calls.
Why did I spend the money for the conversion to Home Highway?
Mick
RE: I can't believe it
Look to your left at the navigation under 'My Plusnet', go to 'My Connection', then to 'CLI number' and you can have up to 5 numbers which you can add or modify yourself.
Don't think you'll find that Plusnet have removed anything.
mickm
Oh yes they have and they sent me tickets to prove it! I had set them up exactly as you describe.
Mick
Why don't you put them back then? :confused:
mickm
Yes, tried that. If I register more than one CLI then I can't access anything outside Plusnet.
Mick
Strange ...
Sorry to hack you off, but I'm using ISDN FRIACO and have had no problem at all this weekend.:|
