I can no longer use FTP
I've used the same FTP package for about 2 years through PN without any problems, but over this last week my connection always drops after uploading about half a meg. The USB modem isn't recognised after being disconnected, so I have to fiddle about disconnecting it, waiting for XP to do that "DO do" noise, reconnect it and wait for another "do DO" noise while it finds it again.
Then it takes 2 attempts to connect.
Why would that be?
1 REPLY
The modem I have no idea, have you tried re-installing the drivers?
For FTP are you in passive mode if so take it off and see if that makes a difference.
