How to regrade to PAYG?
mrchalk
I am currently on Premier option 1. How can i regrade to PAYG 12gb package?
Fixes: 8
Select Upgrade from the end of the menu ribbon under the Plusnet logo.
Select Change your broadband product
Select Plusnet Broadband Pay As You Go £14.99 and click Go
From the drop down on the next page select the appropriate Included monthly data transfer - 12GB (£22.49)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mrchalk
Cheers m8. When will this take effect please? Wink
Liam
An upgrade will usually take effect immediately and you will be charged a pro-rata amount to cover any extra subscription fees due for the current billing month.
Fixes: 8
If the included amount gives a monthly cost which is the same or higher than your current cost then it is immediate as Liam said.
If the amount you choose gives a lower cost, the change does not happen until your next billing date. This a reason why I recommend choosing the right amount (apart from avoiding the regrade fee).
I updated the Changing to PAYG as a result of your query, let me know if you think anything else needs adding.
mrchalk
Thank you elvin & Liam. I have chosen the PAYG 12gb package which is 50p more than i am currently paying. (Premier Option 1 £21.99).
Just wondering where i go to check to see if i have been changed over yet??
BTW elvin, your guide looks spot on m8 Wink
James
Mrchalk,
Looking at your account, you're showing up as being on a PAYG product.
mrchalk
James, thank you for your speedy reply. I know its your job, but ina way i cant believe youre still here listening to us lot nagging & chattin link:censored :lol:
Good on you m8. Wink
Just one thing m8. Does my 12gb reset on 28th Jan when my billing date is. So if i have used say 6gb, i still have 6 to use before the 28th?
Or do i start fresh from now?
Moderators note by James (sallyandjames) : Removed attempt to bypass swear filter : Please read the link:rules
Mand
Yep, your usage will reset on your next billing date (Jan 31st) until then you have 12GB to use.
Enjoy Smiley
mrchalk
Cheers Mand, now wasnt that simple - for a change!! :lol: :lol:
Cheers, all your help is appreciated folks WinkSmiley
Firejack
Please don't be kind to Comms Team and praise them. We need to keep them mean, to keep them keen. Personally I think we should take away their chairs and make them kneel in front of their computers all day. The pain after an hour of adopting this pose should be enough to keep their minds alert and concentrate on fixing all our trivial problems :twisted:
James
Taking away our chairs is going to directly influence our ability to type, thus preventing us responding to your queries, thus increases the amount of moaning you do. Tongue
Plusnet Staff
Plusnet Staff
Hmm...
Liam
James, thank you for your speedy reply. I know its your job, but ina way i cant believe youre still here listening to us lot nagging & chattin <a href="http://portal.plus.net/central/forums/faq.php#1">[censored]</a> :lol:
And just to note... you'll need to reboot your equipment for the change of profile to take effect.
Fixes: 8
Liam, Do they need to reconnect immediately after completing the account change, or should they wait half an hour or so and then reconnect? (I'll add this to my guide)
