How often are Batch Ftp downloads done
How often do f9 do a batch ftp download
reason I ask is i've just requested the SUSE 9.3 FTP iso files, as trying to download them from suse and other sites including bittorrent are slow
thanks
mike
1 REPLY
Plusnet Staff
Plusnet Staff
Batch FTP is scheduled for retirement as it no longer works as it should and is rarely used. If it's not working for the download you want I suggest not using and it will shortly be removed from the portal.
