How long till stable rate set on MaxDsl (so slow) ?
petsyb
Does anyone know How long it will be till my stable rate will be set ?
Ok it used to be 10 days any ideas anyone
https://portal.plus.net/my.html?action=stable_rate says 2mb, as it has done since 20th of may when i went on to max , my speed has never gone above 1mb since moving on to max even though my connection has never dropped below 7mb
bt connection says aprox 800k connection Sad
plus net between 400k and 950k Sad
I used to have a fast 2mb connection Evil
will it ever speed up ?
petsyb
JonathanW
Looking at the results you're reporting, its possible that your exchange is highly contended at the moment. Have you tred running the BT speed test between midnight and seven in the morning? As during that time slot the contention should be at its lowest and you should see a better result from the speed test.
As for the MSR as reported on the portal, this should be set soon based on the information collected during the settling in period.
My stable rate has stuck at 2000Kbps for over 3 weeks now.
petsyb
i'll try and remember to test in the morning
fairdinkum are you on maxdsl ? if so what does your modem connection read ?
the report for my exchange reads
ADSL Line check
Telephone number : #############
BT exchange : RIPLEY
Real time check : Yes
Line speed capabilities
Rate adaptive (250k and 500k) : Green
Fixed Rate (1000k and 2000k) : Green
MAX speed (upto 8000k) : Green (5500 kbps)
250k, 500k, 1000k, 2000k and 5500k are all available on this line.
Line status
This line has ADSL fully installed on it. There are no open orders currently on this line.
Exchange status
This exchange is fully enabled for rate adaptive (500k) ADSL, fully enabled for fixed rate (1000k and 2000k) ADSL, and fully enabled for Max ADSL (upto 8000k).
There are 5 DSLAMS in the RIPLEY exchange
does this mean anything to anyone , should i be getting 5500 kbps ? ? ?
Petsyb
