How long does email stay active?
After you leave Plusnet how long does your email and webspace stay active?
benoh
If its downgraded to a free account it will remain active for 3 months unless you log into either
Email
Dial in
Portal?
FTP?
Although best checking with support as to which services will keep it active as it may have changed
Ben
Did you request your account to be changed to a PAYGO one when you left? If not then you won't have access to your emails as it is not automatic to change an account to PAYGO, you have to request it.
If it is a PAYGO account, just login to webmail at least once every 3 months and it will keep your account and email addresses active.
Sorry, I should have said, a friend of mine has migrated to another adsl provider and after 2 weeks he can't log in to his old Plusnet email accounts. would it be that this has coincided with his old monthly billing period ending.
lhorwath
unless the customer specifically asked us to keep the account active as a Free (PAYG) account, we would cancel it by default. If they want it reopening, then simply call support and we will turn it back on for them.
Thanks for that. I don't think he'll need it.
