How long before BRAS updates?
Snarf
Been maxed for 4 days now, I've been connecting at between 2100 and 2200 kbps each time the router has been on, however the ip profile on the line hasn't moved from 1000 kbps. I'm getting pretty much the same speed that I was before I was maxxed. Tests before have shown that the line should support somewhere between 1 and 2 Mbps, though before ADSLMax I was never on faster than 1Mbps.
Given the connection d/l speed, should I expect the ip profile to go up from 1000 kbps, or will that pretty much be the maximum I can hope for?
1 REPLY
Boundey
It should take about 3 days but its not uncommon for it to take the full 10 days to fully adjust.
Best thing to do is to re-sync about once every day. That way you get a variation of sync speeds to find your stable rate.
