How do i know if i've been dslMAXed
How do i know if i am now on dslmax, my connection has been up and down like a yoyo the the last few weeks since moving house?
If you look at your routers line stats the (US) Up Stream figure will be 448 (I think).
If posible post the routers line stats someone should be able to confirm it..
router says:
Data Rate
Downstream/Upstream 6816Kb/448Kb
but running speed tests show nothing like this speed, i get something between 400 - 2000 down, 300 or so up?.. surely it should be more than this..
What is your reported stable rate?
follow this link
http://portal.plus.net/my.html?action=stable_rate
follow this link
current broadband speed is 5500 Kbps
Liam
Hi there oldhand,
Your account has indeed been maxed.
When are you experiencing the slowdowns?
Could you do a speedtest here for me?
http://www.speedtest.bbmax.co.uk And tell me what you get.
Have you tried any BT Speedtests when you're experiencing the slowdowns?
The slowdowns are not really at any specific times, i have been testing in the evenings say between 6pm - 9pm..ish the speed varies from day to day...
just now at http://www.speedtest.bbmax.co.uk..
Download Speed: 2390 kbps (298.8 KB/sec transfer rate)
Upload Speed: 372 kbps (46.5 KB/sec transfer rate)
Liam
That speed, to be honest, is perfectly acceptable for this time of day.
The best speeds you'll get are in the early hours of course, but around now until about midnight is probably the busiest time on the net.
yeah, i am not too upset by thi speed... but it is when it goes down to 400kbps i am concerned..
