How do i get interleaving turned ON?
dannykos
just wondering because i don't do gaming - and want a more stable connection - seem to be getting frequent disconnects still on LLU.
Do i need to raise a ticket - can somone in the know do this directly? (mandy / dave t?)
James
Re: How do i get interleaving turned ON?
Hiya,
If you are on Tiscali LLU, you will have an 8ms interleaving profile turned on by default. How often is your connection dropping?
dannykos
probably 3 or 4 times a day i suppose - it's the old "LCP is allowed to come up" router message problem.
"LCP is allowed to come up" means nothing on it's own, you need to back it up with further evidence. That message occurs on PPP drop, sync drop, router restart/etc.
You need to state exactly what kind of connection drop it is.
dannykos
don't really know to be honest - all i know is that through the day - the connection drops, and when i check the router - on the connection status under negotiation it says "LCP is allowed to come up" - but i still have sync. If i power cycle the router, then it's usually fine again - but not always, as sometimes it hangs in the same manner, even after the reboot.
Using a netgear DG834GT.
i tend to just suck it up - and get over it, but thought that interleaving might help (not knowing it was ON by default on LLU)
