How do I raise a ticket to report a fault with my service pl
kiasu
I just keep going round in circles trying to find where this is now.............
They don't make it easy!!!
Cheers
1 REPLY
No it's not easy anymore but do the following.
Use the Help and Support section and follow the trail that most suits your problem.
When you have got to thepoint that a wizard starts to run but it still doesn't give you anything useful then close the window that the wizard is running in.
You will then find that as if by magic there is now an option to ask a "Question" (raise a ticket) that has appeared.
