How dare you plus.net!!
For the last 2 months I've been used to a really poor user experience on non standard ports (http/ssh) during late afternoon/everning.
My ssh sessions running on non standard port currently has a RTT time of 50msec instead of the usuall 1+ second I would expect at this time.
This is not on!!! Im going to be so anoyed if it reverts to retarded mode tomorrow!
** secretly hopeing you fixed something **
Fixes: 4
Re: How dare you plus.net!!
We fixed the VPN/SSH signatures today and made some changes to the queues. Keep your fingers crossed, but that should fix it.
Glad it's better! Cheesy
Boundey
Yip i know what you mean. It means working remotely on any PC in the evening is IMPOSSIBLE!!
Its really doing my head in right now. My work e-mail is running at snails pace. I could run to the recipients house faster than it would be to send e-mails. By the way our work using a secure encrypted connection (FirstClass) not a normal POP3, SMTP setup.
Seriously, someone get this sorted!! Or just ditch those ellacoya's till it sorted. Surely someone at PN must have a backup plan in place for this problem as im sure you are loosing a lot of customers and customer value now.
Fixes: 4
You are seeing it bad now?
Boundey
yIP, VERY BAD AT THE MOMENT.
Fixes: 4
And the application being used is 'FirstClass'?
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
Boundey
That is correct mate.
The port it uses is 510. Not sure if thats anything to go on with the ellacoyas technology.
Thanks for helping out on this. Smiley
Fixes: 4
This one huh? http://www.firstclass.com/
I've just found
510 TCP fcp FirstClass Protocol
510 UDP fcp FirstClass Protocol
Talking to our guys atm about it. We can use that info to look further.
Boundey
Thats the one mate.
If you need any information to go on, or to connect to my works server then let me know and i can sort something out.
blowdart
Funny, I'm not seeing any problems with FirstClass to the OU's servers.
Boundey
To where?
blowdart
The server I connect to at the open university.
Boundey
Using the client or the web version?
blowdart
Client, obviously, otherwise I wouldn't have commented, heh. Not much point in pointing out the web version works.
Boundey
Well you never know some people these days.
You obviously dont know the kind of people i have to put up with in the education sector do you? :?
Anyways - I have just tried your OU FirstClass servers and it takes about 30 seconds for it to tell me my username and password is incorrect. It hangs an awful long time on 'exchanging encryption details.'
