How come gaming in my usage
Gaming 115.55MB 33.67MB 149.22MB
I dont have any games on my pc, so are we to assume that plusnet are cheating me of some of my downloads ratio. lol.
if not why would this be showing up.
That could be anything from background internet noise to mis-identified webcam.
At those amounts I'd not be concerned.
thanks matey.
another concern is that when i run speed test at bt i get 6249 kbps
when i run at plusnet i cant reach 3000 kbps.
my connection speed is supposedly 8mb.
Plusnet Staff
Plusnet Staff
I wouldn't worry about the speed result from the portal speedtest as it's not been designed for Max and will give odd results, we're shortly going to replace it with this
http://www.mybroadbandspeedtest.com
I'd compare the results from that with
http://www.speedtest.bbmax.co.uk
If they are also showing around 3000kbps then run this test
http://www.dslreports.com/tweaks
and post back the result URL.
Both the test sites say that license has expired lol.
Plusnet Staff
Plusnet Staff
Strange, they both work OK for me, do you have the latest Flash player installed? Also have you checked your clock to make sure it has the right date and year? Can't think of anything else really that would cause that kind of error on both sites.
When i tried to run them it did indeedy say about the flash player, i installed the latest, restarted pc then got the "licence expired" message.
Working now mr tomlinson, one giving 6254 (broadbandMax) other giving just on 5134,
Looking better
sorry posted twice
Joe_Scaramanga
I ran the speed test on PN website the other day and I got 0.0... :shock:
Quite odd considering I had been happily surfing away with no problems.
