How accurate are activation dates...
...and how long after activation does the adsl go live for use :?:
Just wondering since my activation date from BT according to PN is today after 12 - so will the internet be live tonight :?:
Activation dates are pretty accurate, but remember, theyare only a provisional advisory date, and not confirmation your line will be activated.
Some are activated before, some on and a few straglers after.
You should receive an email once your activation is complete and confirmed by BT.
Also, you should know before PlusNet if BT have performed the activation, by if or not your line is in sync with the exchange. This information is normaly available from your router.
My view is take the dates as a pinch of salt....
Mine seems to change every day!
1st it was the 25th then by the 29th , then by the 5th now.... don't know check in another 24 hours and the reason......unknown
I am only 1/4 mile from the exchange with nothing in between and I could have run a complete cable down there in an afternoon!
Oh and as you can guess I am not happy Evil (especially at not getting a reason and just being told to basically wait)
