Horrible laggy browsing but fast speedtests
Fixes: 61
You can normally get the information from your router - if you advise the one you use I am sure someone will be able to help
petsyb
it's a usb modem !
Fixes: 61
I am a bit out of my depth here as I have never used a USB modem but I think this is controlled by windows.
In this case the first thing to do is clear the DNS cache and see if that helps - this page explains how
http://www.updatexp.com/dns-windows-xp.html
then you could also check how XP is finding the DNS server - it should be automatically - see this page
http://www.microsoft.com/windowsxp/using/networking/expert/tcpipdns.mspx
lyndonp
it's a usb modem !
If you bring up a command prompt by clicking Start, Run, then type "cmd" without the quotes
then type at the prompt "ipconfig/all" (again without the quotes) it will show you the DNS Servers on one of the lines.
petsyb
thx
DNS Servers . . . . . . . . . . . : 212.159.6.10
212.159.6.9
I know i can set these as fixed, but what are the plusnet dns servers ?
thx
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
Optional tertiary DNS server 212.159.6.9
See here.
I've edited my original post subject title as this thread has taken on a life of it's own Smiley
lyndonp
thx
212.159.6.9
I have the DNS automatically assigned on my router and have exactly the same DNS servers as yourself - .9 and .10
I have noticed before that the automatically assigned servers are not what PN publish as their Primary and Sencondary (.9 appears as tertiary and .10 isn't shown at all! :roll: )
Saying that I have not had an issue getting web pages to come up, but being as I have router switched on 24/7 I don't think the DNS would change until I rebooted the router and picked up the auto DNS again.
I wonder if because you are using an ADSL modem that at the time you experienced the issue the auto DNS was different :?:
Are you still experiencing problems? If so, or it occurs again check the DNS at that time to see if it is any different.
I prefer using the auto assigned DNS as that way if PN need to change anything I will automatically get the new ones.
Maybe somebody from PN could explain why the auto assigned DNS are different to those published please.
Plusnet Leader
Plusnet Leader
We have 4 DNS servers that can be assigned when hardware is set to auto. These are:
212.159.13.49
212.159.13.50
212.159.6.9
212.159.6.10
davefitz
I have been having this problem as well.
I can be browsing a site and suddenly get a 404 error when clicking a link, hit refresh a couple of times and it usually appears eventually.
I'm on ag1 so will try to connect to ag2 and see if it helps.
Fixes: 61
my experience for what it's worth (before I switched to RIN) was that
212.159.13.49
212.159.13.50
were more reliable
I've been getting the same thing for the last 4-5 days.
Browsing very slow, and gradually gets worse through the day until it's 404 all the time.
Disconnecting & reconnecting the modem seems to be be the only way to get the browser working again.
I'm on LLU with a USB modem.
Just to say, when I started this thread, dave t suggested I reboot my router and try to get on ptn-ag2; I didn't bother at the time as things had improved.
Just did a reboot for another reason, found myself on ptn-ag2. immediately started seeing a small forest of packet-loss on my l8nc graphs.
rebooted again and got back on thn-ag1 -- all clear again.
i always seem to see a load of packet loss on ptn-ag2, wondered why?
