Homepages
Homepages
I have ported my Webpages to PlusNet and was
wondering about setting up my Home Page as the
default homepage when I login to PlusNet. I thought
the Homepage facility at the head of the PlusNet
homepage might be the way to do it but I couldnt
get it to work. I assume there is a way to do it
and would be grateful if somebody could tell me.
I also assume that my PlusNet controls will still
be available superimposed on my Home Page.
1 REPLY
RE: Homepages
> Thanks
If you're using Internet Explorer you can set the page to be used as your homepage by going into Tools, Internet Options. Here you will be able to type in any web address to use as your start page when opening Internet Explorer.
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
