Home Surf / BBYW
Home Surf / BBYW
Are there any other Home Surf customers still around thinking of moving to BBYW? I'm currently paying £18.99 for a 20Gb limit. However, the most I've ever used so far is 4Gb (inc off peak), what would others recommend with regards to moving to BBYW?
As far as I can tell, if I moved to option 2 I would loose 12Gb, loose 8AM-4PM off-peak, gain P2P, gain better hosting and gain 4 quid a month.
As Home Surf is so old are there any plans to force customers off it? Decisions decisions.
1 REPLY
Plusnet Leader
Plusnet Leader
Home Surf / BBYW
TBH it's completely upto you regarding the package that you want. If you only use 4Gb per month then why not change to a new package and save yourself a few quid?? - you'll gain some new features too like P2P.
Whatever happens if you want to stay on Home Surf then we have no plans at all to force you to change.
