Home Page
Home Page
I am a new member and notice that to access my email I have to sign on with my ID and password twice, once on the home page and then again on the Plus Mail page.
Am I missing something here? Is a direct link to the inbox possible with just one sign in please?
PS. Very impressed with the service so far. Thanks.
RE: Home Page
Good Evening,
I'm glad that you're happy with the service. Thanks for letting us know.
Onto your problem.
Was there a delay from when you logged onto the portal to when you logged onto the webmail? Or did you just select webmail shortly after logging in?
Kind Regards
Duncan
| Duncan Scotland          Unmetered & ADSL solutions
| Senior Technical Consultant   for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ------- My Referrals - It pays to recommend PlusNet ---------
RE: Home Page
> Good Evening,
> Onto your problem.
> Kind Regards
> Duncan
> If you sign in at the "my mail" box on the home page it takes you straight to the Plus Mail page. No delay noticed. From there you have to sign in again and that takes you to the inbox.
RE: Home Page
> > Good Evening,
> > Onto your problem.
> > Kind Regards
> > Duncan
> This is not a problem as such but I just wondered if it was possible to go straight to the inbox by only signing in once?
RE: Home Page
It always does that... its like the code on the submit button on the main page points to the same place as the link on the PlusMail bit on the side bar...
RE: Home Page
Good Evening,
It shouldn't be doing that. Please just confirm that the address bar shows http://portal.plus.net/ for both times when you have to log in.
Kind Regards
Duncan
RE: Home Page
> Good Evening,
> Kind Regards
> Duncan
On the first (home ) page the link is ---
http://portal.plus.net/imap.html?pn_session= (lots of numbers which I havent posted incase security is an issue)Then --
That takes you to the Plusmail page and the next link is ---
http://portal.plus.net/imap.html? (another load of numbers) which takes you to the inbox. Hope this helps.
Ill check back tomorrow evening. Thanks for your interest.
RE: Home Page
In my experience, it's ALWAYS been like this - I now always click PlusMail from the side bar then log in - submitting details on the front page has never effected a login in to PlusMail (though I'm sure it was meant to).
Aid Simons
> Good Evening,
> Kind Regards
> Duncan
RE: Home Page
Good morning all,
Have you set up the Auto-login feature? This should cut out the need to login to different parts of our portal. You can choose how long the Auto login lasts (Hours, Days, Weeks or Years).
Please let me know if I can help you any furteher.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Senior Technical Consultant...........for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: Home Page
Hello again,
Just to add to the posting I have made above.
The reason you have to login twice is that there are 2 types of mail login, because there are 2 ways of using our PlusMail service. Here's a brief overview:
1. Mailbox Login (The bar on the top of the Portal)
Use this to access mail sent to a specific mailbox (if you have set one
up)
e.g. mailboxname@accountname.plus.com
Mailboxes are a really useful tool. You can find more about them here: http://portal.plus.net/supportpages.html?a=162
(You can manage your Mailboxes from the Portal's "My Control Panel")
N.B. If you don't have any mailboxes set-up, you will be taken to your default inbox (where your email sent to anything@username.plus.com goes).
2. PlusMail Login (The link on the left hand menu)
Use this to access your email normally (if you haven't set-up mailboxes)
So, if you don't want to check a specific mailbox, or if you haven't set any up yet, the best solution is to use the link on the left-hand menu to access your email, and that way, you'll only have to login once.
If you need any extra information with these features, have a look at our Support Pages http://portal.plus.net/supportpages.html?a=11 they're really helpful and have screenshots too.
I hope this brief overview explains things for you better!
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions Senior
| Technical Consultant...........for Home & Business PlusNet
+ ------ My Referrals - It pays to recommend PlusNet ------
RE: Home Page
> Hello again,
> up)
> Regards,
> Dave
Thanks for all your help.
