High ping
High ping
When running cmd>ping>webaddress - I seem to be getting high pings, or latency,not sure if it is our router or force9...
I may need the connection details for our router again, I know the username and password just things like the number which should go into VPI / VCI / Encapsulation (LLC VC ) / QoS etc...
It is only been like this the last few days can't think of anything which has changed here as far as wiring, and settings, the only thing I can think of is the reset of the router which I have tried and reboots to TRY to sort the problem, as when listening to various radio streams on the internet I get constant buffering and issues when connecting due to this Sad Not sure if anyone can eprhaps help at all?
Reply from 82.195.155.17: bytes=32 time=348ms TTL=120
Reply from 82.195.155.17: bytes=32 time=340ms TTL=120
Reply from 82.195.155.17: bytes=32 time=383ms TTL=120
Reply from 82.195.155.17: bytes=32 time=520ms TTL=120
Ping statistics for 82.195.155.17:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 340ms, Maximum = 520ms, Average = 397ms
Ben_Brown
High ping
Can you post a tracroute to the site you're trying to ping, it'll give us a better idea of where the problem is.
High ping
What do I do to do that lol sorry.
Ben_Brown
High ping
You do it like you'd do a ping, apart from you type "tracert" instead of ping.
High ping
Tracing route to listen.bitrateradio.com [82.195.155.17]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms mygateway.ar7 [192.168.1.1]
2 15 ms 15 ms 74 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 15 ms 16 ms 66 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 41 ms 51 ms 15 ms ge1-0-0-23.ptn-gw1.plus.net [212.159.4.17]
5 15 ms 95 ms 15 ms 195.66.226.167
6 180 ms 164 ms 226 ms 84.203.130.90
7 92 ms 27 ms 25 ms 84.203.138.118
8 27 ms 66 ms 26 ms 3.150.reserved.hosting365.ie [82.195.150.3]
9 191 ms 202 ms 158 ms listen.bitrateradio.com [82.195.155.17]
Trace complete.
