High Pings
High Pings
Hello all again.
I'm getting high pings in CS, 80-100, it has been fine all day! Anyone else getting this?
High Pings
Yes, on our german UT2k4 server I have over 300ping and 7% packet loss. Evil
High Pings
Yes!
I've been getting lag spikes (mainly caused by packet loss and choke) in CSS for the past 2 days making the game unplayable. The internet wouldn't even connect this morning.
As a paying customer I'd like to see this problem sorted out :roll:
High Pings
Yep - had enough. Ordered MAC.
High Pings
I've checked the speed test, and i'm getting what i should be. And i've not exceeded my monthly download. So, i don't know what it is. The ping has decreased to about 60-80 on servers now.
If anyone knows whats going on, please say.
High Pings
Can you post a tracert to the server. We might get an idea where the problem lies from that.
High Pings
Can you explain how i am to do that, as i've forgot, lol. Tongue.
High Pings
Well, the pings have stabalized now. If you could explain how i do a tracert, and if it happens again, i will do it and post the info on the forum.
Cheers.
High Pings
from a command prompt type tracert <server name or IP> enter
copy the result to the board.
Hope that helps jog the memory. Smiley
High Pings
All i get is:-
Unable to resolve system target name
with each IP i put in.
High Pings
Ok, the results to www.plus.net are as follows.
1 1 ms 1 ms 1 ms voyager.home [192.168.1.1]
2 135 ms 83 ms 81 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 91 ms 121 ms 94 ms ge0-0-0-503.pte-gw2.plus.net [84.92.4.82]
4 110 ms 107 ms 105 ms ge0-0-0-23.pte-gw1.plus.net [212.159.4.25]
5 100 ms 93 ms 96 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 92 ms 102 ms 98 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 159 ms 193 ms 182 ms if2.ptb-al1.plus.net [195.166.129.39]
8 109 ms 103 ms 94 ms portal.plus.net [212.159.8.137]
Hope this helps.
Cheers.
High Pings
@ pcsni
I am not on any games but have a look at this one Mark it is to a web site in Australia have done it several times in past 10 minutes with varying results the last one had second hope way up there at 510ms
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Jim>tracert www.swiftdsl.com.au
Tracing route to corpweb.swiftel.com.au [202.154.92.59]
over a maximum of 30 hops:
1 20 ms 2 ms 2 ms mygateway.ar7 [192.168.1.1]
2 49 ms 30 ms 29 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 47 ms 29 ms 28 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 46 ms 31 ms 29 ms ge-8-0.er1b.lhr3.uk.above.net [209.249.11.101]
5 43 ms 29 ms 33 ms so-2-0-0.cr1.lhr3.uk.above.net [208.184.231.153]
6 112 ms 101 ms 101 ms so-4-0-0.cr1.dca2.us.above.net [64.125.27.57]
7 138 ms 144 ms 145 ms so-7-1-0.cr2.ord2.us.above.net [64.125.27.17]
8 141 ms 125 ms 125 ms so-0-0-0.cr1.ord2.us.above.net [64.125.29.185]
9 202 ms 193 ms 195 ms so-4-0-0.mpr3.sjc2.us.above.net [64.125.30.213]
10 195 ms 193 ms 195 ms so [64.125.30.2]
11 199 ms 201 ms 193 ms so-5-0-0.mpr4.pao1.us.above.net [64.125.29.125]
12 188 ms 209 ms 189 ms above-gige.pao.singtel.net [64.125.13.6]
13 202 ms 194 ms 190 ms 203.208.168.137
14 350 ms 352 ms 341 ms 203.208.148.78
15 397 ms 401 ms 396 ms ge3 [61.88.181.146]
16 407 ms 410 ms 415 ms peopletelecomm.o6ssc76fe.optus.net.au [59.154.14
.2]
17 1234 ms 408 ms 410 ms www.swiftdsl.com.au [202.154.92.59]
Trace complete.
High Pings
Well, i know about pings, as i play games alot. And their well high in the hops.
Get it sorted a.s.a.p. Tongue. Is it worth turning my router off then off?
High Pings
To plus.net...
1 42 ms 42 ms 41 ms lo0-plusnet.thn-ag1.plus.net [195.166.128.80]
2 43 ms 65 ms 44 ms gi0-2-0-303.pte-gw2.plus.net [84.92.3.178]
3 49 ms 46 ms 42 ms ge0-0-0-23.pte-gw1.plus.net [212.159.4.25]
4 59 ms 56 ms 48 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
5 49 ms 52 ms 47 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
6 54 ms 54 ms 52 ms if2.ptb-al1.plus.net [195.166.129.39]
7 57 ms 66 ms 66 ms portal.plus.net [212.159.8.137]
Strange... it only seems to affect me during games. Perhaps it's certain ports?
High Pings
@ Widdows
Try reconnecting again and running traces until you see yourself connected via the ptn-ag1, ptn-ag2 or thn gateways.
@ haggis2
The latency issue seems to be lying outside of the +net network (at around the 3rd or 4th above.net router)
