Help please
Help please
Hi there think i have a major problem with my computer this morning when booting up error message cc pp not accessible try reloading the programme again.
Then Norton is telling me that there is a protection problem a sypware problem and a phishing protection problem when i go to fix these it's telling me Norton has an internal programme error
[Moderator's note by Jonathan (chillypenguin): Case dropped on all CAPS title, as it is considered shouting and very rude, see link:rules.]
James
Help please
Have you tried uninstalling and reinstalling norton and then running a full system scan?
I'd also recommend installing and running a couple pieces of saftware such as "Adaware" and "Spybot - Search and Destroy".
Fixes: 57
Help please
To really fix it you might have to uninstall Norton using this tool
Help please
Try here for advice:
http://www.antionline.com
Steve
