Help needed with getting the Coranto CGI Script to work on P
Hi Everyone!
(Just for the record, the problem with the CGI server seems to have dissapeared now! It was annoying me this morning though when tech support kept saying there wasn't a problem!!!) Smiley
I'm having problems with getting Coranto to work on Plusnet...This is the script below...What do I need to change to get it working? (I'm getting a server error/misconfiguration error at the moment)
Regards
Oli
#!/usr/bin/perl
# Before attempting to set up this script, please read
# readme.txt, which you should have received along with this!
# MICROSOFT IIS COMPATIBILITY
# Set the following variable to one of the following:
# $IIS = 0; # The default - auto-detect. Usually works fine.
# $IIS = 1; # You're on IIS -- do basic IIS compatibility.
# $IIS = 2; # You're on IIS, and you still had problems when $IIS was 1.
# $IIS = -1; # You're not on IIS - disable even the auto-detection.
$IIS = 0;
# END OF SETTINGS (unless you encounter problems - then fill out the next section)
# EXTRA SERVER INFORMATION
# Coranto tries to determine its path and URL automatically. This works in 90%
# of cases, but some servers aren't cooperative and don't allow this information
# to be found automatically. Though it won't hurt, there's no need to fill this out
# unless you encounter problems.
# If you encounter problems (particularly with incorrect URLs, or fatal error messages
# about files not being found), fill in the two variables below.
$abspath = '/cgi-bin/coranto/';
# Set the above to the absolute path to Coranto's directory, without
# a trailing slash. Example:
# $abspath = '/absolute/path/to/coranto';
$scripturl = 'http://www.treetops.plus.com/cgi-bin/coranto/coranto.cgi';
# Set the above to the URL to coranto.cgi. Example:
# $scripturl = 'http://www.myserver.com/coranto/coranto.cgi';
# END EXTRA SERVER INFORMATION
# START (Unless you know Perl, don't change anything after this point.)
# Don't change this number! Used internally.
$crcgiBuild = 29;
# In order to trap as many errors as possible, we run everything via an eval.
# If $JustLoadSubs is set, that means we're being included by an external
# script which doesn't want us to run, so don't.
unless ($JustLoadSubs) {
# Disable warnings and redirect warn signals to fatal errors.
$^W = 0;
$SIG{__WARN__} = sub { die @_; };
# The following commented section causes the warn function to do nothing.
# It's useful only with modules that insist on warnings.
#package CORE::GLOBAL;
#use subs 'warn';
#sub warn { }
#package main;
eval {
main();
if ($@) {
CRdie("Untrapped Error: $@");
# This is the first sub to be executed.
sub main {
# Try and be compatible with Microsoft IIS.
if ($IIS >= 0) {
if ($IIS == 0) {
if ($ENV{'SERVER_SOFTWARE'} =~ /IIS/) {
$IIS = 1;
if (($IIS) && ($0 =~ m!(.*)(\\|\/)!)) {
chdir($1);
if ($IIS == 2) {
print "HTTP/1.0 200 OK\n";
# If extra server information was specified, use it.
push(@INC, $abspath) if $abspath;
# We're done. Now load the core and start running it.
NeedFile('crcore.pl');
RunCoranto();
# Takes care of loading in external Perl files.
my %LoadedFiles;
sub NeedFile {
my $file = shift;
unless ($LoadedFiles{$file}) {
eval { require $file; };
if ($@) {
if (-e $file) {
if (-r $file) {
CRdie("Could not include file $file. The file, however, appears to exist. This usually indicates
some form of syntax error in the file. Message: $@");
else {
CRdie("Could not include file $file. The file appears to exist but is not readable. Check file permissions. Full Message: $@");
else {
CRdie("Could not include file $file. The file does not appear to exist. Verify that this file is where it should be.<br>Full Message: $@",1);
$LoadedFiles{$file} = 1;
# Gets our current absolute path. Needed for error messages.
sub GetDirInfo {
my $cwd;
eval q~use Cwd; $cwd = cwd();~;
unless ($cwd) {
$cwd = `pwd`; chomp $pwd;
$cwd =~ s!\\!/!g;
return $cwd;
# Gets our full URL. Needed for error messages.
sub GetScriptURL {
my $url = 'http://' . ($ENV{'HTTP_HOST'} ? $ENV{'HTTP_HOST'} : $ENV{'SERVER_NAME'}) .
($ENV{'SERVER_PORT'} != 80 && $ENV{'HTTP_HOST'} !~ /:/ ? ":$ENV{'SERVER_PORT'}" : '') .
$ENV{'SCRIPT_NAME'};
return $url;
# CRHTMLHead: Displays the standard HTML header used by all script pages.
sub CRHTMLHead {
unless ($HTMLHeaderPrinted) {
my ($title, $adminnav) = @_;
$title =~ s/</&lt;/g;
$title =~ s/>/&gt;/g;
$title =~ s/"/&quot;/g;
print qq~
<html><head><title>Coranto: $title</title> $Messages{'ContentType'}
print PrintCSS();
# HOOK: CRHTMLHead_Head
if($Addons{'CRHTMLHead_Head'}){my $w;foreach $w (@{$Addons{'CRHTMLHead_Head'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
print '</head> <body link="#D00000" vlink="#D00000" alink="#D00000" class="bodybg">';
# HOOK: CRHTMLHead
if($Addons{'CRHTMLHead'}){my $w;foreach $w (@{$Addons{'CRHTMLHead'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
print q~
<table width="70%" border="0" cellpadding="2" align="center" cellspacing="2">
<tr><td><div align="center" class="miniheader">~;
print qq~ <a href="$CConfig{'SiteLink'}">~ if $CConfig{'SiteLink'};
print $CConfig{'SiteTitle'};
print '</a>' if $CConfig{'SiteLink'};
print qq~
</div></td><td><div align="center"><a href="http://www.amphibianweb.com/coranto/" class="miniheader">Coranto
$CorantoVersion</a></div></td></tr><tr>
<td colspan="2" class="darkgbg">
<table width="100%" border="0" cellspacing="0" cellpadding="2" class="redbg"><tr><td>
<div align="center" class="largeheader">$title</div></td></tr></table></td></tr></table>
<br>
<div align="center"><h4>This is beta software. <a href="http://www.amphibianweb.com/coranto/forum/">Report bugs!</a></h4></div>
# HOOK: CRHTMLHead_Message
if($Addons{'CRHTMLHead_Message'}){my $w;foreach $w (@{$Addons{'CRHTMLHead_Message'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
print qq~
<table width="90%" border="0" cellspacing="0" cellpadding="4" class="redbg" align="center">
<tr><td><table width="100%" border="0" cellspacing="0" cellpadding="6" class="whitebg" align="center">
<tr><td>
if ($CurrentUser) {
print qq~<table width="80%" border="0" cellspacing="0" cellpadding="2" align="center" class="yellowbg">
<tr><td><div align="center" class="miniheader"> $Messages{'LoggedIn'} $CurrentUser.~;
if ($adminnav) {
print '<br>back to the ' . PageLink( {'action' => 'mainpage'} ) . 'Main Page</a> | back to ' .
PageLink( {'action' => 'admin'} ) . 'Administration</a>';
# HOOK: CRHTMLHead_UserBar
if($Addons{'CRHTMLHead_UserBar'}){my $w;foreach $w (@{$Addons{'CRHTMLHead_UserBar'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
print'</div></td></tr></table><br>';
$HTMLHeaderPrinted = 1;
} # end unless $HTMLHeaderPrinted
# This roundabout method of printing CSS code exists to make things easier for addons.
sub PrintCSS {
my $css = $CConfig{'HeadCSS'};
# HOOK: PrintCSS
if($Addons{'PrintCSS'}){my $w;foreach $w (@{$Addons{'PrintCSS'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
if ($css) {
return qq~<style type="text/css">
$css
</style>~;
else {
return q~<link rel="stylesheet" type="text/css" href="http://www.amphibianweb.com/coranto/crscript.css">~;
sub CRHTMLFoot_NoNav {
print '</td></tr></table></td></tr></table></body></html>';
# CRHTMLFoot: Displays the HTML footer used by all script pages.
sub CRHTMLFoot {
print '</td></tr></table></td></tr></table>';
print q~<br><table width="70%" border="0" cellspacing="0" cellpadding="2" align="center" class="redbg">
<tr><td><table width="100%" border="0" cellspacing="0" cellpadding="8" class="navlink">
<tr><td><div align="center">
my $mpage = $Messages{'Section_MainPage'};
$mpage =~ s/ /&nbsp;/g;
print PageLink( {'action' => 'mainpage'} ) . "$mpage</a> | ";
my @funclist = map { $_->[0] =~ s/ /&nbsp;/; PageLink( {'action' => $_->[2]}) . "$_->[0]</a>&nbsp;" } @AvailableFunctions;
# HOOK: CRHTMLFoot
if($Addons{'CRHTMLFoot'}){my $w;foreach $w (@{$Addons{'CRHTMLFoot'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
print join('| ', reverse(@funclist));
if ($CConfig{'SiteLink'}) {
print qq~| <a href="$CConfig{'SiteLink'}">$Messages{'BackTo'}&nbsp;$CConfig{'SiteTitle'}</a> ~;
print q~</div></td></tr></table></td></tr></table>~;
# HOOK: CRHTMLFoot_2
if($Addons{'CRHTMLFoot_2'}){my $w;foreach $w (@{$Addons{'CRHTMLFoot_2'}}){my $addon=$w->[2];eval ${$w->[0]};AErr($addon,$@)if $@;};}
print '</body></html>';
# CRdie: Generates a pretty error message with as much information as possible.
sub CRdie {
if ($CRdied) {
exit;
undef %Addons;
$CRdied++;
my $msg = shift;
my $enableHTML = shift;
$msg =~ s/\n//g;
$msg =~ s/<br>/\n/g;
unless ($enableHTML) {
$msg =~ s/</&lt;/g;
$msg =~ s/>/&gt;/g;
$msg =~ s/\n/<br>/g;
if (!$HeaderPrinted) {
print "Content-type: text/html\nCache-control: no-cache\n\n";
if (!$HTMLHeaderPrinted) {
CRHTMLHead("Fatal Error");
print qq~<div align="center">An error has occurred. The exact description of the error is:</div>
<table width="80%" border="0" cellpadding="2" align="center"><tr class="fieldtitle"><td class="whitebg">
<div align="center">$msg</div></td></tr></table>
<p>If this error indicates a problem that you don't know how to solve, see the Coranto documentation
and FAQ. If these resources don't help, make a (detailed!) post to the <a href="http://www.amphibianweb.com/coranto/forum/">Coranto Forum</a>.</p>
<table width="90%" border="0" align="center" cellpadding="3" class="yellowbg"><tr><td class="footnote"><hr><div align="center"><b>USEFUL INFORMATION</b></div>\n<br>~;
if ($!) {
print "Perl may have generated the following error: $!\n<br>";
print "Perl Version: $]\n<br>";
print "Script Version: $CorantoVersion\n<br>";
print "Script Build: $coreBuild\n<br>";
print "Script URL: $scripturl\n<br>";
print '@INC: <ul><li>' . join("</li>\n<li>", @INC) . '</li></ul>';
($0 =~ m,(.*)/[^/]+,) && unshift (@INC, "$1");
($0 =~ m,(.*)\\[^\\]+,) && unshift (@INC, "$1");
print "Script Location (Method 1): $0\n<br>";
my $dirname = GetDirInfo();
$dirname =~ s/\\/\//g;
print "Script Location (Method 2): $dirname\n<br>";
print "<br>\n<b>ENVIRONMENT VARIABLES</b>\n<br>";
while (($key, $value) = each %ENV) {
unless ($key eq "HTTP_COOKIE") {
print "$key: $value\n<br>";
print "<br>\n<b>MESSAGE:</b> $msg\n<br>";
print '<hr></td></tr></table>';
CRHTMLFoot_NoNav();
exit;
1;
RE: Help needed with getting the Coranto CGI Script to work
> Hi Everyone!
> Regards
> Oli
Hi Oli,
I'd be lying if I said I know Perl properly - so I can't really support you on this. Just remember that we do run UNIX servers, so make sure you set non-IIS. Another thing, you may want to post this to our CGI newsgroup, there's a lot of talent there.
Regards,
Mike
| Mike Grice........................Unmetered & ADSL solutions
| Customer Support...........................for Home & Business
| PlusNet Technologies Ltd...............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
Thanks a lot :-)
> Thanks a lot :-)
No probs Oli. Let us know how you get on Smiley
Mike
