Help - alias problem!
I've just discovered that I don't seem to be able to change which address an alias is pointed at.
Let me explain further as it might just be this particular alias. I decided to point 'postmaster' at our joint address so I wouldn't have to keep forwarding PlusNet newsletters, billing info etc to my husband. Unfortunately, I failed to remember that 'Topic Reply Notifications' are also sent to 'postmaster', with the result that he's now getting all those too.
Best solution if there's no way of getting it pointing back to the default (or changing it to my personal address) would be if 'Topic Reply Notifications' could be sent to that rather than to postmaster.
Hope someone can help me!
Plusnet user since November 2003
Currently on Unlimited Fibre Extra and Unlimited UK & Mobile Calls
Plusnet Leader
Plusnet Leader
If you let me know the email address that you want the notifications sent to then I can get it changed for you. PM me the details and i'll try and sort it for you Cheesy
Thanks Chris. Have done as asked.
Plusnet Leader
Plusnet Leader
This has now been changed for you.
Don't hesitate to give us a shout if you have any further questions.
Thanks! I can see notifications are coming to my personal address now. Phew!
Plusnet Leader
Plusnet Leader
No problem Cheesy Glad its sorted out.
