Help Assistant Question formating
Fixes: 5
I've just asked a question using the Help Assistant. When you go and view "My Questions" my question is there without the line breaks in it, making it much harder to read.
I added a comment to the question, as I'd forgotten a little detail that might be helpful, and this one does have the line breaks in.
I assume the script that processes the initial questions doesn't handle the line breaks as it should, but the others are ok.
Anyone else noticed this?
Phil
Edit: Question ID is 19407209, if any of the comms team want to see what I mean.
1 REPLY
Fixes: 8
Yes.
Link
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
