Has something gone badly wrong
Fixes: 57
Lost connection through RIN so switched back to PlusNet and that worked.
Back to RIN and that worked for a couple of minutes then everything timed out.
Back to PlusNet - seems to be OK but Usergroup Forum won't load
Also RSS Feed Service Status doesn't load
Fixes: 5
Usergroup forums aren't working for me at the moment from my work (Non PlusNet) connection. Can't test RIN at the moment because as I say I'm not at home.
Phil
Fixes: 69
Afternoon guys.
usertools.plus.net and usergroup.plus.net are currently down (they're both hosted on the same box).
We've raised a priority one problem and we have an engineer investigating a we speak.
Kind Rgds,
Plusnet Products Team
Fixes: 57
Thanks Bob,
Any news on RIN problems
Update - tried RIN again and site loading very slow.
Tried BBMax speedtest
RIN 235/206
PlusNet 2561/351
Liam
Shouldn't be any reason why you are having any difficulties with RIN. Have you tried a BT Speedtest whilst connected to the RIN network? Do you see significantly poorer performance than when connected to our Network?
By the way, the P1 on Usertools is published here :
http://www.plus.net/support/service/problems/problem.php?intProblemId=42007
Fixes: 57
Did BT speedtest and results OK
Tried BBMax and that is back to normal - odd - must have been a very short glitch
