Has cron died on ccgi again?
ramses
Hi
My cronjob has not run on ccgi since Tuesday 3rd July. I suspect that cron has died again on the cgi server.
(see: http://portal.plus.net/central/forums/viewtopic.php?t=56800&highlight=cron )
Is any one else having problems with cron again?
Richard
Other users have report permission problems changing their crontab's today.
But as for crontab running, mine appears fine.
Check out this link;
http://ccgi.chillypenguin.plus.com/lastcron.txt
It should update every minute.
Chilly
ramses
Ok, thanks for that.
You reminded me that last time cron went wrong I created a cronjob to run every minute to test it. I've uncommented that test in the crontab and it is working OK after all.
I hope my main cronjob runs as normal tomorrow, because I'm not sure I understand why it would suddenly stop working otherwise.
Cheers
Richard
ramses
... so my cronjob didn't run again today (Friday 6/7). When I went to edit my cronjob I find out that my crontab is empty!!
Has anyone else seen this? What a pain.
Richard
Just checked my link above and it reported;
Fri Jul  6 17:03:14 BST 2007
Looks like something has gone wrong.
Chilly
Same here;
chillypenguin@cshell01:~$ crontab -l
no crontab for chillypenguin
Reloaded my cron tab and "crontab -l" shows the entries but my lastcron.txt is not updating so crontab is not running.
Chilly
Ticket ID: 22303617
Plusnet Staff
Plusnet Staff
Fixes: 159
This is with our networks guys to resolve now. They should find the cause of the issue and fix it.
 Chris Parr
 Plusnet Staff
I have now raise PUGIT item 33 as this is the second time recently that it has stopped and there is clearly no monitoring in place to detect it.
Plusnet Staff
Plusnet Staff
Fixes: 159
I've raised a problem internally to get this looked at and a fix for this implemented.
 Chris Parr
 Plusnet Staff
Still not working!!!
STILL not working. Clearly this does not have any priority :?
Shockedops: http://ccgi.chillypenguin.plus.com/lastcron.txt Shockedops:
Is still showing;
Chilly
Hi Peter
Must be our mistake there is no issue with the CGI servers;
Or at least according to the service status page.
Chilly
ffupi
Hello
Did come from here http://portal.plus.net/central/forums/viewtopic.php?t=57319 .
Is still showing;
Chilly
Same to Chilly I found that cron stopped at: Friday, Jul. 6 - last update at 1702 (5:02 pm) BST .
However, before that for two days was already erratically cronjobs done.
I had set up this: http://portal.plus.net/central/forums/viewtopic.php?t=56563&highlight=load and it tells that the server which serves cron is hopelessly overworked (at least that is what I uderstand from the red bars, all above 5 - whatever that means - ). On the 3rd July it was creaping up the day over to 30.38. Then there is no recording for the 4rd of July, so it was not working on that day. On the 5th July it runs on a top plateau of 33.32 until ca. 11.12am, then it collapses to only sporadic responses for the further day, the time is only sometimes recorded and at at ca. 22:24 there is yellow small bars only. The next recording is only covering part of the 6th July, none for the 7th July, and for the 8th July when I only once started the script manually.
Is there anyone who could write a small script for PlusNet which scans cron. I am sure there is a lot of people who could do it and help out. :?:
And - I guess - the server which runs cron needs some jobs taken off it. :?:
