Half speed at dawn
Half speed at dawn
I'm getting approx half my normal speed during the Core Router Maintenance work which was slated for 4-7am today. I'm reporting it because the Status announcement doesn't list slowdowns as one of the possible symptoms of this work. (Coming in on pte-ag1). So - is this likely to be a result of the works or should I be worried?
Simon
1 REPLY
Half speed at dawn
I was having DNS issues (ie I could connect to the plusnet portal but that was pretty much it) so I rebooted my router and couldn't reconnect. I've powered the router down while I'm at work and will try reconnecting when I get home from work at 12 I'll try reconnecting and raise a ticket if it fails. It would be nice if Bob or someone could comment on this if it's affecting multiple users tho Smiley
