HTTP download test
HTTP download test
Can anyone recommend somewhere with very fast servers where I can test a large http download?
The last two things I've needed to download haven't broken 17kb/s once settled, wanna see if it's the servers or me.
Thanks Cheesy
HTTP download test
Why not just use the speedchecker?, if your downloading from usnet then 17K is pretty good - I normally only get 15K :roll:
HTTP download test
Well, the +net checker doesn't work.
18-09-2005 09:56:16 24189
15-09-2005 20:16:43 11075.3
14-09-2005 22:37:02 0
13-09-2005 16:07:03 0
13-09-2005 16:06:48 0
13-09-2005 16:01:41 7247.4
If only I got those speeds Cheesy *drools*
Anyway, BT test, ADSLguide and zen test all check out, so I just wanted to check it wasn't a problem with HTTP downloads Smiley
HTTP download test
Not to worry, slackware iso levelled off at 210kb/s - not perfect, but better than 17 Smiley
Cheers
Plusnet Staff
Plusnet Staff
HTTP download test
Try http://ftp.heanet.ie/, generally seems to give really good http and ftp speeds.
HTTP download test
While we're here, any idea why the +Net speed checker doesn't work?
I disable NIS and Ad-Watch, even tried disabling router's firewall, but I either get a reading of 0 or several thousand megabits Cheesy
Ben_Brown
HTTP download test
Have you tried an alternative browser?
I've not had any problems with it in Opera.
HTTP download test
I'll fire up IE and give it a whirl Smiley
(Been using Mozilla)
HTTP download test
Got a result with I.E :|
You'd think the fastest growing browser would work :roll:
Anyway, nice call Smiley
LiamM
HTTP download test
You running Firefox? If so... works fine for me using Firefox.
HTTP download test
Yup, running Firefox. Doesn't work at all, even with everything disabled.
I have the google toolbar plugin and that's about it... Sad
I did wanna get rid of IE completely, but so many Microsoft services will only use IE and not Firefox, I kept it Cheesy
Ben_Brown
HTTP download test
I've just tried it with Firefox at home via vpn and it worked ok. It was on debian, not that that should make any difference.
